Oog
So I have a 1989 f250 7.3 idi turbo 5spd 4x4.
I have purchased an autozoo special flywheel and clutch, and have run into an issue.
When I called Perfection clutch, they told me I need 3/8-16x2.25" bolts to hold the flywheel to the crank.
Nobody here has them, the jump is from 2.00 to 2.50"
Has anyone used the 2.00" bolts without ill effects? Or should I buy 2.50" bolts and cut them down to an appropriate length?
If anyone has any new 2.25" bolts, I will buy them from you.
