Sludge on Lift pump.
IDIn_It
Pensacola FL
Epump is plumbed up. Need to get some more clamps and get it wired up. Found out that white powdery stuff on the fuel hose wipes off ooops lol
BDCarrillo
Abilene TX
Good luck with that pump. I had one die in the first 15 minutes used as a pusher transfer pump.
IDIn_It
Pensacola FL
I've been running the hell out of it to get old fuel out of the tanks lol I'll eventually upgrade to a facet pump.
That's where it should be for those. Closest to the tank as possible.
I've never ran the diesel one, but had the gas version, since it was already in my truck when I put the diesel in. It went a good 5 or so years. About 3 pumping gas, 2 diesel.
IDIn_It
Pensacola FL
I wired up my pump tonight and some how blew the 20 amp fuse that's for the glow plug controller. I have the signal coming from the fSS to the relay. Then I have an inline fuse coming from the starter relay hot side to the relay. I have the hot side of the pump going to the relay. Ground is on the inner fender. Its all wired correctly.
IDIn_It
Pensacola FL
Here are pics on how I got it set up.
No, I wrecked and parted the truck.
But actually I then used it on my 88 f250 I had for a while also. Then parted it, too. Lol
