ToughOldFord
The Cold Glow-Plug
Ooops, sorry about that, Chevy_Eater is me over at FTE.
Maybe the difference is the sensor for the factory gauge?
I use the rearward plug on the D/S head myself. I like to keep the factory equipment working:
12 point socket should work.
Sent from my SM-G900R4 using Tapatalk
It's a square plug so it has to be an 8 point socket. (8 points are olde school so they aren't real common, but they are out there).
So 8 point 9/16, preferably 1/2 drive or better as the plugs can be stubborn.
Or a weatherhead socket. They are made for elbows and square plugs
Thanx gary, I'm gunna swap the overtemp back there so I do 't have to stare at the dash light!Using the rear port on the heads is not telling you the highest temp the engine gets. The coolant flow comes up from the cylinders back there and flows forwards to the front of the block. Thats exactly why the over temp switch is located in front of the cylinder head.
I've temped both ends with an infrared thermometer, the difference is minuscule.
If thats what you feel is correct then run where you want. I also have a infrared temp gun and see much different temps no matter what I shoot compared to my Isspro after market mechanical or electronic gauges. Not at gauges are correct nor are the guns. It is a fact the coolant flows from the back of the engines to the fronts. Thats why the temp switches are located up front. That location of the small sender on top of the block to the drivers side of the injection pump is in a blending chamber that runs under the injection pump to the other side where it combines with the passenger side just before it sees the thermostat. Might be a little too much information to digest but its good reading just the same.
That's funny. Pretty sure that's what I used.Nope
And on all the other square heads.
