Chuckdiesel
Well I have been getting good at shifting now without using the clutch and was wondering if that really is not a good idea? Shure gives my foot a break
Synchronizers are basically tiny little clutches, made to raise or lower the speeds of the gears to match. If your engine speed is already matched to the road speed for the gear you are going into, the synchronizers don't have to do anything.
...it feels smooth but the weight i put on the shifter is placing strain against the syncronizers and they are trying to line things up. they cant because they are not able to overcome the engine speed instead of just the clutch disk when you do depress the clutch.
so i can see where you would be silently smoking your syncros until you do find that sweet spot unless you can hit it spot on every time.
There seems to be some kind of lure which comes from professional drivers that seems to suggest that you never need to use your clutch. I've had truck driver friends tell me of people who NEVER used it, including starting from a stand still. Now I don't know a lot about large truck transmissions, and I suppose if the gears are bigger, and low enough that you might be able to get away with this, BUT... I do have a good sense of engineering and manufacturing, and I challenge you to find me ANY operators manual that encourages the use of shifting without a clutch. You find me a manual that says "The clutch is to be used in extreme emergencies only, and it's use should be avoided at all cost" and I'll eat my shorts. I've never been able to understand the fascination of not using it. To be honest, if your foot or leg gets tired, you probably should have an automatic. No offense intended, and there was no reason not to ask this question. I'm just throwing out my 2 cents. I have heard they have started to develop "automatic manual transmissions" in the trucking industry where there is some kind of computer controlled clutch and shifting action going on, and that sounds really amazing. Nothing like taking a simple system and making it as complicated as you can.
