Mr_Roboto
Basically with double clutching, you are matching the engine RPM to the road speed for the gear you are shifting into. This is necessary in most big trucks since most are not synchronized (since synchros are extra weight, and another part to wear out / break).
To upshift: clutch in, trans in neutral, clutch out, drop engine 300 RPM, clutch in, shift up one gear.
To downshift: clutch in, trans in neutral, clutch out, increase engine 300 RPM, clutch in, shift down one gear.
It isn't as hard as it sounds, once you learn how you do it automatically. (The 300 rpm difference is for the Super 10 trans, other gear spacings will require different RPM changes). In practice, to get the 300 RPM increase, you blip the throttle and catch the right RPM as it is coming down.
When it's cold my wrecker's synchros don't work, so I get to practice double clutching......
