I have been reading alot here lately about issues buying the proper length belts. I run a 112 inch Nappa belt on my rig with 7 ribs. I did run a 111 inch belt for some time but... It wont fit under the vacuum pump pulley... Thats not a bad thing either if you have the hydroboost brakes. Your vacuum then is only used for the ac vents and criuse control unless you have a C6 trans.... Hope this helps you guys out... Also the tensioners all have a spec mark on them telling you the belt fits in the spec range... Thanks kinda nice. I bet it will tell us when the belt has stretched past its usefull life....
