Seized Hydraulic Head on IP
mjs2011
Brookings, SD
I just got the news from the diesel shop that hydraulic head on my IP was seized.
It is all rebuilt now and is on its way back to me. He didn't charge me for a core either.
But anyway, I am just wondering what can cause the hydraulic head to seize.
ifrythings
BC
Ive heard that stuck shut injectors can and also spraying the ip while its running with cold water can case the hydrolic head to shrink and seize to the rotor, dirt could probably do it also and mybe too thick of an oil? Others will have a better idea
mjs2011
Brookings, SD
Those are some of the things he was suggesting. I was running cold WVO when It happened, I know it was my mistake, just want to learn from this and avoid it in the future.
Was the main shaft broken... Whats posted so far are reasons for this. Sounds like your engine may not have been able to crank too. Who did the repairs and do you trust them for doing a good job.
mjs2011
Brookings, SD
Main shaft was not broken, The engine was able to crank over. I was recommended by a few folks to have H&H diesel do the rebuild, I took the pump off my self and sent it to them. They seemed knowledgable when I talked to them on the phone.
He only mentioned that the hydraulic head was seized, didnt say that the main shaft was broke.
FarmerFrank
Blairsville, Pa
If the head seized, then the main shaft broke. If it stopped moving and the timing gears are still turning that little shaft is the weak point.
I had one lock up when 20* straight WMO hit the pump while it was running last winter.
Your case was probably the wvo was in there and was too thick for it to move
jaluhn83
Upper Marlboro, MD
WVO. Trying to run too thick of fluid causes too much stress on the pump internals. Imagine trying to pump cold gear oil.....
