BJS
If done correctly the drilling and slotting does not weaken the rotors at all.
I'd be intrested to see the drilled/slotted replacement rotors for these trucks as to if they are a solid piece or are they a modified version of what we had from the factory a vented rotor (2 pieces of metal w/ fins between them).
In theory you have less frictional surface but are allowing for greater heat dissipation through surface area for the air to contact.
The holes & slots would also provide even when sitting still a greater propensity for cooling especially when you are forced to sit with your foot on the brakes after a hard stop. Convection currents work wonders for cooling in liquids as well as in the air which is where even when not moving the drilled/slotted rotors will benefit. When it comes to a reduced mass of the rotors I sincerely doubt that there is any significant reduction in mass as most makers compensate by making the metal thicker and decreasing the vent area between what is esseentially 2 different disks.
