Routing wires from passanger side to engine bay
kc0stp
30 Hour Famine
Colorado
Whats the easiest way to route wires from the passangers footwell into the engine bay?
RLDSL
Diesel fuel abuser
Arkansas
Yup, if you have an air drill, with a step drill bit it will go real fast. make it a nice big hole , then after you run the wires fill in the gap with silicone, then if you ever need to run anything else, you already have a hole, and all you have to do is poke out the silicone
kc0stp
30 Hour Famine
Colorado
Any idea where roughly would be clear of heater/ac parts (looking from inside) was going to drill a hole but looking at it from the engine side looks like theres a lot of HVAC stuff in the way
PackRat239
Illinois/ SW Fla.
You also have the big plug in the floorpan that gives access to the front cab mount bolts. The cab mount is open in the front too, so you can easily pull some big ol honking wires thru there without drilling.
PR
All answers are correct,
One question...What is this wire you are having to run into the engine comp on the pass side...just curious...
Al
kc0stp
30 Hour Famine
Colorado
Thanks for the replies folks :)
Al
Currently power wires for a ham radio (much more powerful CB on diffrent frequencies), already had the right side a-piller trim off to run the antenna wire so just ran the power wires down on that side, eventully plan on adding a switch panel as well. (have a shelf at top of windshield)
I'll snap some pics tomorrow of my power feed setup in the Bronco tomorrow, maybe it can give you an idea! As well as try n do same for the white rhino...both have/had 2M radios. I like the Bronco setup most ;)
kc0stp
30 Hour Famine
Colorado
Radio test fitted but prior to wires ran, figure eventully have the switch panel running between radio and door on the left.
tke395
