Hydro-idi
Even though many will disagree with my comments about seafoam, you can add an entire bottle of seafoam to fresh oil and leave it in for 3k miles. I have talked to the seafoam tech person and he said it will not harm anything but you should change the oil oil before the 3k mile marker if you see that the oil is getting very dirty. But most add a bottle with old oil and use it to "flush" an engine out.
Blackbear, if you have popped the valve covers off and everything seems to be in good working order, I am still leaning towards a worn or dirty lifter. Seafoam will clean a dirty lifter...but will not cure a worn lifter.
