fordviehman
Hi new to the forum and IDI's.
Just bought a 1990 F-250 with a 7.3 and a ZF-5. It had sat for over 4 years before I bought it. I pumped all the old fuel out of the truck and put new fuel and diesel klean in it and it started in about 5 seconds after turning it once for about 15 the first turn of the key. Fast forward about three weeks after I replaced all the filters I started to get hard to start conditions and white smoke at start up especially when it sits overnight. My thought is the return lines got bumped, I also have a fuel leak while the motor is running that comes down the passenger side exhaust manifold. The return lines need to be replaced anyway because they are dry rotted from sitting and as hard as a rock. Do you guys agree that they are most likely my problem?
Thank you,
Ford V (yes my name actually is Ford)
Thank you,
