Radiator Relocation
chillman88
Central NY
Personally I'm curious if having that hardline from the frame rail to the radiator gives you trouble. I'd be worried about flex causing problems.
Chad241993
Blackfoot ID
Only thing I see is you will want a bung in the upper hose on the engine to fill/bleed air. Just looks like a 1/2 pipe plug there. Will work but might fight filling being that small. Most guys put a second cap on
The Radiator sits higher than the cross over, I am hoping it will just be for bleeding air.
There should be enough movement I'm not way worried about it and at $23 a foot for coolant hose I'm using it sparingly.
fyrfghter
Lebanon OR
I don’t have any insight on coolant routing but do you have more pictures of your truggy??
Jrlew87
