Question about brakes on 84' 3/4 ton
billybobjethro
Drivers side rotor needs replacing. The brakes are dual piston disc brakes. The truck is a 4x4 with manual locking hubs.The front axle is a 3850lbs. So my question is, is the hub/bearing assembly pressed, holding the rotor in place? When I've replaced rotors on other vehicles it was a different design. Usually just remove the tire, the caliper and a couple of bolts or set screws then it's off. This looks like the locking hub assembly has to be removed to get to the rotor, and when I went to the parts store to get the rotor, they were talking about a hub bearing assembly with the rotor, this just seems to much. Any info out there is welcome.
Thanx,
Brandon
