Do not remove the motor with the torque converter attached. Thats the wrong way and you will ruin the seals in the front of the trans.... Plus the converter will need to slide out around 4 or 5 inches before it comes off the input shaft on the trans. Remove the 4 bolts that hold the converter to the flexplate. You will need to turn the motor around to reach all 4 bolts. A small lever or large screw driver on the starter gear will move the motor....
