Pull your oil filler cap, listen, what do you hear?
Rot Box
Northern Utah
Lewiston
Mine sounds like the very soft idle of a two stroke dirtbike about a block away. Ting...tinng tinng.... tingg.... ting. Maybe its just me :dunno I think I'll grab another cold one :rotflmao
DOE-SST
1994 E350
Geeez,
everyone's a comedian.cookoo
well, almost everyone.;Really
I heard a rapid, metallic "clink":eek:
So, I pulled the cover off the IP gear mount, and found my screws starting to back out.
Thank you dyoung14, :hail:hail:hail
you win an internet. :thumbsup:
It will be delivered to the CD-ROM platter on your computer shortly.:Thumbs Up
I told ya everyone's a comedian. LOLLOLLOLLOLLOL
dyoung14
Is getting worn out
spencer,tn
Geeez,
:rotflmao sontimes im helpful, but yes i went threw the same thing, except mine ruined the pump cover and the inspection cover so consider yourself lucky, when i caught mine it sounded just like the engine was knocking when i pulled the cover 2 bolts were gone and the last one was about to fall out:eek: were did the go? who knows but im sure something didnt like them when it found them-cuss
SLC97SR5
UT
Mine sounds like a shrill whistle.
If you roll up a piece of paper and stick it in the filler neck the noise nearly goes away. I think this is because the threads of the filler neck are acting as flutes...does any of that make sense??
h2odrx
Anti-O
Coastal Neckville, NC
You must be an engineer?
Mine has been quite for some time now.... got to replace those injectors...
tke395
