Fullsize4life
Now with More Smoke
Anyone ever run it on a idi? Im kinda thinking about maybe trying it on mine. Im not sure though. Im looking for just a little more in the hp and mpg areas.
I can elaborate a little more on mine tomorrow if you wish.
I wonder if water/methanol injection would be better, then you could stuff more fuel in without superheating the air charge. Methanol also burns pretty good. Water injection isn't cheap though unless you make it yourself and if you do that you darn well better know what you're doing.
First pull, no LPG
HP 183.15 Torque 325.45
2nd and 3rd pull with LPG
HP 205.35 Torque 362.64
HP 205.51 Torque 361.55
So 22.96 increase in HP
and 37.19 increase in Torque.
Ok, heres the lowdown on my propane system:
20#LPG tank in the tool box. 12V shut off silinoid, adjustable acetylene regulator at the tank that knocks it down to about 20 PSI. Then it goes to another adjustable regulator under the hood that that is set at about 7 PSI. Then it is dumped into the air stream behind the air filter.
To activate the system I have a red switch on the switch panel that turns on the system. There is a small switch that is located by the go pedal that activates the propane at about 3/4 throttle.
That is the basic system that I used on the IDI, Turbo and non turbo. When I switched to the Cummins I added a boost switch that is adjustable from 4 to 20 PSI. It is set to come on at anything above 10 PSI. That way no LPG will flow unless there is fuel and plenty of air first.
Pretty basic system but it works. I think it works better on the Cummins as far as power gains than on the IDI.
The down side is that there is not an adjustable regulator that will give it more LPG at a higher boost, it is either on or off. I could and may set up a dual system that will come in and add more LPG at 20 PSI and higher but that is just a thought for now.
Here are the dyno results when I had it on my IDI:
Hope this helps yall, gotta go for now,.
