Power
dyoung14
Is getting worn out
spencer,tn
Well im buying a non wastegated psd turbo, it wont get mounted on the truck for a while, cause i got to get all the bugs out of the truck, i will probly just start out with the stock psd turbo but later on i will upgrade it and put a fast spool exuast housing on it, I plan on putting a 4000 rpm governer spring in and the bb code injectors from russ and i will probly max my ip out 3 inch downpipe 4 inch stacks, max boost of 12-13 psi,(for now) i think it should put down some pretty good numbers, if i get it all right i will go find a dyno locally and i will throw it on it and see what she will do
