I checked with a machine shop do bore 6.9 and other work. He said that the oilers are pressed in and will need to be replaced. What has anyone done on these. I bought the new 40 over pistons and .010 shorter, ARP studs and now ready to get machine work done. Ford makes better cam bearings, is this correct or does he just want to up price. I am checking price to have piston tops coated. Is around 850 about right for machine work. Clean,bore, pressure test for pin holes, surface block, new oilers and cam bearings. 150 to balance. I plan to get torque cam fron Type 4 as well as injectors. Hoping to be safe, I bought 10 under on bearings with rering kit. The machinist said the cranks are tough and seldom need to be turned, if so should I get standard or have it turned even if it checks out okay? I don't have a bottomless pocket, but I want this build to be right. ALL input is THANKED ahead of time.
Herb
Herb
