We have not heard from Towcat on these piston rings yet. He has made some posts about a set of rings that outlast all the others. They are expensive but the best usually is more costly. I hope he chimes in on this because he knows what he is talking about when it comes to these engines lasting longer. What he knows is proven on his tow fleet first. then it ends up here.
Absolutely! There's nothing like prior experience with a product to help make decisions. That's the great thing about this list. Folks write in with their live-and-up-close view of how things really work. Some work really well and wind up as tech articles. Some don't work so well and wind up in the Hall of Shame.
Towcat's experiences with Total Seal will be great to hear about. His fleet faces hard use over long hours and that's a great test for any product.
The reason I chose TS for my second ring is prior experience. I'm a happy repeat customer. Seven years ago, I ordered the 2nd ring set for my veedub Jetta 1.6TD overhaul. I liked what I saw in terms of mpg, blow-by and butt dyno. Since this truck is being built for the long haul (
seriously long haul), the added expense made sense. My one concern went back to prior experience. I had great results from these rings on a small diesel. What happens when the size increases over 400%?
That's where talking to Keith Jones really helped. Lots of information, good sense of humor, easy to talk to. I took the plunge and spent the money. Now, thanks to Brad S' post, I'm really glad I did:
Here's a closely held secret that I have been doing for some time. I have a total of four motors in service with these rings installed. the oldest has 150k on the ODO. no blowby yet
they are a ***** to put in though.
Basically my vote is for the setup Justin has mentioned plus Total Seal rings.
here's the specs.....
Part Details
Make FORD-LINCOLN, Mercury Model 445CI NAVISTAR DIESEL NON-TURBO, SPECIAL GAP 2ND RING .062”-.072”
Part Number S1474 Available Sizes STD 20 30 40
Dimension Details
Bore Inch 4.110 Bore mm 104.394
Groove Sizes 3.0 2.0 3.46 TSD Cylinder 8
Price $ 408.20
Also Fits
Make Name VehType Make/Model Litre Year Bore Inch Bore mm Groove Size PistonFitment Gapless Top Ring Gapless 2nd Ring Conv Ring Oil Ten Use Available Sizes
FORD-LINCOLN, Mercury Car 445CI NAVISTAR DIESEL NON-TURBO, SPECIAL GAP 2ND RING .062”-.072” 7.3L 89-95 4.110 104.394 3.0 2.0 3.46 TSD S1474 C1474 STD S STD 20 30 40
http://www.totalseal.com/PartDetails.aspx?From=Application
TC posted this over 2 years ago. It'll be good to hear how these rings have held up with commercial use over the past 24 months. Now
there's a road test!
Again, my only concern in a diesel application is that, the modified ring has less SEALING FACE surface area and mass to seal as well as essentially dissipate heat and also being modified has more surface area for carbon buildup or coking between the rings.
Maybe I'm wrong...I don't know I have not proven this either way...it's just me voicing an opinion...
Seems odd they would sell a set of Gapless rings for considerably more money than regular rings and the mods.....????? makes me wonder how long the modded rings last in comparison.
I get it. Here's what I've seen - the set for the Jetta was two piece and so's the set for the 6.9. In my sets, the picture you posted is the outer ring. Behind and below that ring is an L-shaped ring, whose gap in on the other side of the piston. This way, there's no clear path for combustion gasses/debris. You're worried about the sealing surface. When the rings are installed, you
might get a piece of paper between the two rings.
Maybe. There truly is no appreciable loss of sealing surface. What you gain is a gap-free barrier to combustion gas. As far as price, you basically get a 50% rebate if you supply the rings. The finished product looks the same. You just reduced part of the manufacturing cost and that savings is passed back to you. Pretty good deal all around. Now understand, we're just talking about the second ring. If you want the full set, or if you want your first compression ring to be two-piece as well, the cost goes up. Way up.
And yes, they are a PITA to install. But like I keep saying - WORTH IT ! !
