Perfect Stereo for my 88 Bricknose!
Broken_Season
San Jose
So Ive decided to put my CB Radio into the Radio slot. Best fit and best place for it. Next I was trying to figure out simple stereo for the truck.
In my 84 Vanagon I installed a Simple Bluetooth system that uses a very small foot print.
So I found on Amazon a Marine Boos unit that after measuring the cassette pocket to the left of the wait to start light :D .
I pulled the pocket off and I ground down a little bit of the top of the bezel and also had to open up on the dash side. Made a couple cuts and it fits perfect. ( I don't have photos of those cuts but the next time I open the bezel I will) :D .
The wiring on the ford side is odd. But I bought a plug kit for the factory wiring harness. Used constant power green/white wire and the ground wire. (I want to be able to listen to music with the truck off too).
Unit is great for Bluetooth and also has Radio antenna input!
Broken_Season
San Jose
yep I got that cup holder on amazon for cheap. I cant put a big cup on the driver side. But I can in the passenger with it out getting screwed up (unless I have to use reverse)
