ah1988ford
I bough a ip from pensecola and had a mechanic install it ( not a diesel mechanic ), he lined up all of the marks down the front of the engine like he was suppose to but he took the gear cover off when he did. Now the truck has a really difficult time starting we have to use a gas soked rag over the intake to get it started, when it does it blows white/gray smoke out the tail pipe. I have a member on here helping me to get it running right (gonecrazyi). He is way more experienced with these engines than I am and
when we get it running when you push the throttle the "plunger" on the drivers side bottom of the ip it doesnt go in far enough. I am going to run some atf through it in the morning let it sit and run it later in the day to see if mabey it is gunk causing the pump to act up. If you need more info or details just ask, not good at describing really.
