Override gearshift interlock on Panther chassis?
The Warden
MiB Impersonator
Fog Bless Pacifica (CA)
Hello! This is partially a rant, although I do have a legitimate question :D
Yesterday evening, I was picking up clients in an '05 Lincoln Town Car 6-pax stretch. At the last pickup point, I set the parking brake, put the transmission in Park (in that order, so the car was resting on the parking brake and NOT the Park pawl), and got out to help the last client into the car. After she was in the car, I went back to the driver's seat, put my foot on the brake, and pulled the gearshift lever towards me to shift into Drive...and the lever wouldn't come back all the way.
The best I can tell, there's an electric solenoid connected to a switch on the brake pedal; when the pedal's pushed enough to activate the switch, the solenoid releases the gearshift handle and allows you to pull the handle all the way back so that it can move out of the Park detent...and I couldn't hear the customary click that indicates the solenoid was operating. I looked under the dash (in a full suit; THAT was fun :rolleyes: ) and every switch connected to the brake pedal assembly seemed to be working normally, but still no joy. -cuss I'm not sure what exactly happened, but after about 10 minutes of trying, the lever finally came back all the way. I talked to one of my colleagues on the radio and he said that he had been able to get it unstuck by rocking the car back and forth, although given that the problem was with the solenoid and not the car resting on the Park pawl, I don't know HOW that could have worked...
In any event, all's well that ends well, although it was still embarrassing and came uncomfortably close to ruining my clients' wedding :shocked: Now that I'm done ranting :D I do have a question...is there any way in Hades to override that solenoid and get the linkage unlocked "in the field"? In 5 years of driving these cars, this is the first time this has happened to me...and I want to make damn sure that it's the last time this ever happens!! -cuss I imagine the basic system's the same as on the Crown Vic and Grand Marquis...
Thanks in advance ;Sweet
anthonyj
Laurel, MS
l think all that is required is to unplug the solenoid. it has been a while so l am not sure. try switching the engine off but not all the way to lock and leave switch in off and it should shift out of park to neutral where you can restart.
The Warden
MiB Impersonator
I actually did try shutting the engine off as you described, and it still didn't shift.
Any idea what color the wires (or, better yet, the plug) for the solenoid are? Given t hat I just drive these cars and don't do any work on them (thank goodness for a fleet mechanic :angel: ) I confess to not being all THAT familiar with the underside of the dash...I'm not sure where exactly the solenoid's located.
Thanks again :)
anthonyj
Laurel, MS
it is a two connector into the solenoid that is on the top of the column near the base where the shift cable connects. when you switch the engine off you have to have the key off but not locked provided the solenoid is not sticking. there is no power with the switch off to engage the lock. it is hard to get to but not hard to disable.
truckonfire
