oops!!
84ord
Courtenay B.C.
Changing the IP and couldnt figure it out without taking off the gear housing. After I took it off I squeezed it by the water return to get a peek and it was to late. I for sure moved the timing gear. Now what? Any thoughts?
If Im not mistaken I have to turn it till I find the punch mark.
right?
Mr_Roboto
Elyria, near Cleveland Ohio
Well it's too late now.... But what I did was point the bolt closest to the dowel straight up. That way I had an easy point of reference for re-assembly.
Freight_Train
Traitor to the brotherhood
Gadsden,Al
ok,you gotta 50 50 change on getting it right.Line up the marks on the crank and the timing cover.Take the gear on the IP and find the Y marking.Count 19 teeth in each direction from that tooth marked with a Y.Mark said teeth with a paint pen.Now,take a straight edge and connect said dots with a line.Put the gear back in alone with the Y down and the line even with the front of the timing cover.This is not a fool proof method but it is easiest.There is a 50% chance that the gear is now 180 degrees off but that will only mean you need to light up the marks again,Pull the gear out taking note if the Y is on top or bottom this time.If it was on bottom then give the engine a full turn and line up the marks.Now put the gear back on like you did before using the line across the face.Pretty easy and you have a good chance on getting it right the first time.
84ord
Courtenay B.C.
Thanks guys for the help.
Got a pump from dieselcare
hope it all works out
Also thought about gettin that 6.9l from that bus off of ebay: :rolleyes:
zigg
Victoria,Canada
If you have #1 piston to TDC(on compression stroke), then the marks will be lined up correctly 100% of the time!!
Zigg :)
