Been almost a year since i went south to buy my rust free truck. I did not get enough time to work on it too much last summer as i was working it real hard lol. This truck has not been driven in the snow yet and wont be until next winter. So i have some time to buy parts and plan on what to do. Today was the start of finally fixing my fuel gauges!!!
It seems when someone installed a Gooseneck in the bed they drilled into the tank
, which i plugged when i bought the truck.
Well after i plugged that and re-installed the tank, it developed a few pinholes
...which i plugged.
Cant believe a tank that looks this good inside has pinholes.
Wonder why gauge no work
So here is the old and new sender. Got the sender from Summit Racing, its an Auto Meter part # ATM-3262. Sender has an Ohm range of 240/33 so i will need a new gauge as well.
Here is the old feed/return lines installed without the old sender. Going to mount new sender to old plate and extend feed line to the bottom.
The new sender is installed with the old float which was still good. In order to mount it there i used one of the original holes and needed to drill another. The screws that hold it on didnt come with with nuts so i used the two that were on top of the sender with washers. It took some time to get the float rod bent so it would have the full range of motion on the sender. I checked with a multimeter and all is right
. Also extended the feed line with a 3/8 compression fitting and a little 3/8 copper tube. It will all be worth it to have a working fuel gauge!
I also ditched the rollover valve in favor of a 3/4x1/2 copper elbow and some 1/2 inch tube that i ran up in the wheel well.(sorry no pic
) After all this i just re-installed the tank and called it a day. Next up is putting my gauge in the cab and wiring it up.
...was still pumping like it is restricted. I followed the feed line from tank to FSV and it seems the PO had unbolted it at one point and pulled it away from the frame for some reason and there was a kink about 6" from the FSV. Another 3/8 splice from the FSV to just past where the kink was and im ready for another test. FAIL :***:...So now im thinking the FSV is bad because it was pumping great while it was bypassed. Then i got to thinking(even more
)... i have my fuel pump on a toggle switch and didnt have the ignition ON when i was trying to pump through the FSV, does it matter or is my FSV just toast?
