one last ? fuel tanks
smokin_stroker00
dover ohio
Some idiot took the breather tubes out of the filler necks when the mounted the flat bed. Now neither tank takes fuel unless you pull the litlle plug deal out of the top of the tank. So where can you get new breather tubes or what can you use instead? cookoo
sle2115
NRA LIFE MEMBER
Southeast Ohio
There was a discussion on TDS about removing the plug at the end of the top mounted vent hose on our tanks. Some just pulled it out, other fabricated a vent system of sorts, but all said that it made our tanks take fuel. My tank fill vents were inside the fill tube. I replaced them with units that are outside the fill tube, helped some, but I am going to figure out something to vent the top of the tanks better as well.
smokin_stroker00
dover ohio
What I am say is I can't even pour in b100 from a ventless gas can it is that bad -cuss
sle2115
NRA LIFE MEMBER
Southeast Ohio
Yeah, that is bad. I would look at fabricating a new vent for the vent on top of the tank. I pulled the rollover valve out of mine once, WOW, what a difference.
Dsl_Dog_Treat
Decatur,MI
I took the stock check valve/vent assembly off the top of the tank, replaced it with a 3/4" elbow and used about 3' of line and tied it as far above the top of the tank as possible. To keep the crud out of it, I used a kitchen faucet aerator screen tip and clamped it into the end of the tubing.
Works great. ;Sweet Ya I know redneck supreme. :D
Only downfall to it was the fact that I used regular automotive grade hose and is now getting soft. cookoo
It was an inexpensive fix to make sure it was gonna work. Just need to upgrade now to a diesel safe vent line. ;Sweet
**Keep in mind, removing the check valve/vent assembly may allow fuel to drain out of the tank in case of a vehicle rollover.
sle2115
NRA LIFE MEMBER
Southeast Ohio
I would think there would be a bigger (3/4 inch) rollover valve available somewhere!
All the breather is, is a piece of plastic tubing. If you could find some split loom that isn't split (like I see in some factory stuff) or maybe a hose off one of those battery operated Kerosene pumps, or even a regular hose, but you want the diameter to be generous and the walls to be thin so as not to restrict the flow on either side.
snatchal
escanaba, mi
I just bought 2 of THESE to use on a flatbed that I am building. Check with the seller, he may have some left.
smokin_stroker00
dover ohio
I am only about 6 mile from that guy ;Sweet
sle2115
NRA LIFE MEMBER
Southeast Ohio
Exact same ones I have. Not to bust your bubble, but the top of the tank mounted vent is the problem. These helped, now I can set the pump on the lowest lock setting and it will run a while before popping the safety shutoff, but pull the rollover dohicky out of the end of the vent hose on top of the tank and I think I could dump the Valdeze in there! :)
sle2115
NRA LIFE MEMBER
Southeast Ohio
You are talking about the vent in the fill hose, correct? The real problem I have found is the one on top of the tank. I was given the idea over on TDS, and it makes a huge difference removing the valve at the end of the vent on top of the tank. The stock hose is like 3/8, but bigger would do even better I am sure.
oldmisterbill
Grumpy Old Man
Wagoner Oklahoma
I had this problem on a dump bed.I soldered a nipple to thr top of each tank and ran a hose from the top of one tank to the top of the other tank.take both caps off when you fuel and it vents through the other tank filler.
One important point -make sure you have no dip in the line where a slug of fuel can sit or it will slow down the venting.Make the line go up in the middle so as to drain the vent line in case of an over fill.
Mr Bill
sle2115
NRA LIFE MEMBER
Southeast Ohio
Mr Bill
Wow, great idea! I wonder if a vented cap would flow enough air to negate having to remove both caps, not that it is a big problem.
Bo17
