idiabuse
So there it is I have made it this far as a daily driver since I put it all back together.
I have not purchased a single gallon of diesel for it and have not changed the oil either.
I have taken an oil sample but too broke to send it in at the moment.
I have been using 10W30SAE30 weight AMSOIL diesel oil
For the first 1,000 miles I used AMSOIL breakin 30weight oil.
Installed a NOS 30 year old AMSOIL steel can BYPASS filter
I notice it uses about 2 quarts every 3000 miles, it may leak but hell
I aint about to climb under there to fix anything, best I will do is pressure wash it.
So I make my own fuel and don't change the oil and survived this long.
Can I get banned for telling the truth? Probably!
I would love to answer questions!
Oh and by the way I have been the only one that wrenches on this truck since 1999
Javier
Javier
Seems to me thats something a peron really wants to repair. If it was a fuel leak I'm betting you will be on it hot n after it even if the fuel is free. The 20 over is not an issue most of the time. I know of a member that hauled heavy many thousands of miles with a 20 over engine to. Having a 20 over bore is not a death sentence. but it does put us closer to it with cavitation issues. The bypass filter is what I feel all of us should be running. I plan to install a bypass filter soon. Looking at the color of my oil just after a change really bothers me. I will pick up the supply off the drivers side of the block main oil gallery. Then run the return to the lift pump block off plate. Braided stainless steel supply line in 1/8 inch. Rubber return line because there is no pressure on the return. Just gravity flow is all the return is. About 6 months ago I missed getting a free Frantz bypass oil filter at a neighbors house. I saw him setting stuff out for anyone to take. The wifey wanted this huge mirror so I just barely got it into the accord trunk and saw the oil filter in a box. Thought it was going to make a mess in the accord trunk so I passed it up. Driving back home I decided to pick it up... But damn.. It was gone.. Story of my life. Hesitate and al is lost..
! the injector caps only on the pass side leak, driver side dry as a bone.
