It's not too bad at all really. Take the factory sender out of the top of the engine block behind the valley pan.
It's on a tall riser about 4" tall. Your factory sender is threaded into the top of this. Remove the factory sender from the riser.
Go to a hardware store and get:
1) 1/4 NPT "T" fitting
1) 1/4" to 1/8" NPT male to male fitting
1)1/4" to 1/8" NPT reducer
Go to the liquor store and buy:
1) AT LEAST a 6 pack
Drink ONE before you start, and ONE during the install...save the rest for the nascar race when you are done.
Throw away that riser that was threaded into the block.
USE TEFLON TAPE OR PIPE DOPE ON ALL CONNECTIONS!! Leaks are bad!
Insert the male to male fitting into the bottom of the tee fitting. The fitting should go straight up and down with the tee facing 90 degrees to the ground.
The factory sending unit is a 1/4" NPT, so it will thread right into the "T" fitting. Best to put the factory sending unit on top as it is larger than the aftermarket one (in my case anyways)
Thread this whole assembly into the block now. Don't do the next step until this piece is installed into the block or you won't get it threaded in!!
Now, this is where you take your aftermarker gauge sending unit and thread it into the "T" directly, OR if you need to, use a 1/4 to 1/8 recuder.
Run your line (mechanical) or wires (electric/mechanical) and you are done under the hood! Since you are in the process of installing a turbo, you should hae good reach of everything you need to get to. It's a tight area to work in, but do it right once and you won't have to look back.
