WarNose
My transmission was stuck in 1st gear when I got off the freeway yesterday. I didn't notice if the OD light was blinking or not. I didn't even know to look at that until I started researching today. I bought a code reader and its throwing code 92 which means a problem with shift solenoid 2. I checked the wiring harness and it looks good but there is transmission oil inside the wiring harness. Is this normal or a problem? It also has a Banks Transcommand module installed. However I don't have the bypass plug to try running without it. It has a 2013 date on it, so its still pretty new. Thanks.
