mankypro
Learning Slowly...
Since I'm about to replace my Pollak with a 3 way valve and I'm losing the use of the oem in dash tank selector and I thought that I would try something.
I have a spare instrument panel. And since the only gauge that works on my current dash besides the Speedo and Tach is the fuel gauge - I was thinking of taking the fuel gauge from the second dash, trimming it's face a little (to make it fit in the oem oil pressure gauge's spot and directly wiring both senders to the backs of the gauges. I'll tape off the foil oem connector film before attaching the sender cables.
Is there any reason direct wiring the senders won't work?
