akoldnav
I have very odd oil pressure readings on my 1988 F250. I have an aftermarket Westach Oil Pressure Gauge that is really great. Now the problem:
Cool oil shows over 40 lbs of pressure
Warm oil shows 18 lbs at idle and appx 35-40 at cruise.
But at higher curise (over 4 lbs of boost) the oil pressure reading drops off to below zero. I actually tried standing on the brake and just advancing the trhottle in drive and at 4 lbs of boost the oil pressure just went to below zero. If I let off of the throttle the oil pressure comes right back up to 40 lbs. I have changed out the sender and that changed nothing.
The oil pressure senders are connected to the top of the turbo, and I suspect that the spinning shaft has a sort of suction effect that is not allowing the oil to enter the "T" fitting that comes out the side of the top of the Banks Sidewinder. Does this sound possible?
Where would be a better place to put this sensor.
help
akoldnav
help
akoldnav
