'86 6.9 with Banks, according to PO odo has not rolled and shows ~85k miles. The past week or so the truck has occasionally been hard to start. It will crank fast like normal but not fire for 20-40 seconds of cranking in 2-3 cycles. When it fired it runs normal, no missing. I am suspecting injectors may be nearing end of life as it has knocked a couple times like a stuck injector maybe or firing early.
The first time it did this was a week or so ago and was a tank venting problem, tank had a vacuum. Tank is now venting properly but still it will crank a long time before starting. Every time it has done this is when at operating temp and has been off for 20-40 minutes, though not every time. Seems to do it more frequently if parked on an angle vs level, or could be coincidence or me being crazy. On a cold start every morning or after sitting for many hours it has always fired off right away. Only time I've had hard starts is with temps around 0* this winter, and that turned out to be a loose connection on my second battery resulting in it cranking over slowly.
I'm thinking air in the system maybe return caps not sealing and the vacuum in the tank found a weak point to pull air? Or could be the pump getting ready to fail, not sure of symptoms? Something else?
