ok so im putting the nv4500 that was with my cummins in the 92 ford dually. the dually had an e4od. i dont see a speedo cable anywhere, did they not use one on the e4od? or on the nv4500?
No speedo cables at all. The sensor in the rear diff handles the speedo function in place of the cable. Makes it easy to put whatever trans you want into the truck.
