The_Josh_Bear
Did you crack as many injectors as possible to purge the air from the injector lines by cranking it with them open? They will EVENTUALLY fire up if you don't crack them, but it can take multiple battery charge cycles, or maybe never with a weak pump. Years ago, before I got an E-pump I had an IP get air-locked so bad it took me 3 full battery charges and still couldn't get it to go. I drive stick shifts for many reasons...pull-start for the win! It still took over a full block in 3rd gear being pulled before it fired on it's own. Ridiculous... I'm sure most of that was due to a weak/old IP and I didn't crack many lines early in the whole debacle.
OH, crack the lines, get some gasoline in a spray bottle you don't care about. Have someone turn over the beast and spray into the intake. You can actually run it like this till your hand cramps up from pumping. But anyway it'll save your batteries and starter to purge the air. Just use your head around gasoline mist. DON'T cycle the glow plugs or make sparks or smoke... etc.
Hope you get it fired up,
Joshua
Joshua
