How exactly is that supposed to work? Valve float as I explained earlier is when the valves fail to re-seat. Solid lifters don't cause valve float so how could a hydraulic lifter which can not grow cause valve float? Perhaps we are using the term valve float to mean two different things or perhaps something else is occurring and you are attributing it to valve float. I'm not trying to be a ******* just really confused because my truck will get close to 100 psi of oil pressure when cold and I've never had an issue. It's a Cummins not a International but I'm having a hard time understanding how high oil pressure could cause the valves to not seat unless the valves springs are very weak then maybe instead of the lifter affecting the valves the pushrod flowing enough oil to create a situation in which the valve is being held open. I suppose that might be possible although those springs would have to be very very weak.
