fordf350man
hey everyone, well its snowing again here in Michigan what a surprise, spent a good part of the day repairing a corroded wire on the truck causing some slow cranking issues in the snow and cold weather so i got that fixed and thought i wanted to drive the truck as it sat all weekend and i was feeling good getting that accomplished so i took the truck to the store to get some baby supplies on the way back got stuck in some snow, went to put it in 4wd and got nothing , only 2wd was working, pissed me off because a week ago it worked like a dream luckily got it out by rocking the truck back and fourth and a little pushing, so i am wondering if anyone else has had this problem, checked the linkage and everything there is ok, i haven't checked to see if the front drive shaft is spinning yet because its till snowing like crazy and its dark and cold, no noise when shifting no clunking or anything, shifts like it normally would just not getting 4wd, should also add that i am not getting 4lo either, so i am thinking something inside the transfer case is the cause, what do you all think
