New F350 purchase - but its' an automatic ....
OnDaRoad
On the road ....
Dayton, OH
More maintenance ....
Continuing ....
Replaced all the original heater & radiator hoses
One of the heater hoses had a ' factory t ' and a 1/2" line
ran down to the bottom of the radiator
Engine is equipped with block heater
Flushed the cooling system & recovery tank
Installed Fleetguard from YT Tractor Supply
Replaced the glow plug controller & all the glow plugs
Installed Motorcraft glow plugs
Replaced the front brake flexible lines and bled the system
CDR valve is blown - going to run line down from valve to keep
oil out of the turbo air intake until I get a new CDR valve ;Really
Just need to check & set the static engine timing,
idi cold start advance & advance ;Sweet
Jim
That 1/2" line to the Rad is to warm up the trans fluid before the T'stat opens.
On the cold start, if the connector is not plugged in on the temp sensor, the one next to #1 cyl., the cold advance will not energize, it will de-energize when the head temp reaches 120*. In the pix, it's the one just below where the #1 GP is pointed to.
Reading all the posts came across this.
deep
window tinting.
Window tint is illegal in Ohio with an Ohio registration. Fine $85, court cost $65.
OnDaRoad
On the road ....
Dayton, OH
Interested in adoption?
Bill,
Good to talk with you on the phone yesterday ;Sweet
Can I interest you in adopting me & my truck :sly
Thanks so much for sharing your wisdom ......
Jim :D
truckonfire
