need turbo if possible!
Montana Cowboy
Chinook Montana
hay thanks guys for the info. i did buy the pickup! and it is great. now i was wonder ing if you could put a turbo on the 6.9 diesels. and if you know were the best pace is to get them. and may be a drivers door for and 1985 pickup!
david85
Campbell River, B.C.
Banks, ATS or hypermax all have made kits for years for the 6.9, its your call which one to go with (new or used). Any one of them will make the truck a whole different animal. The stock head bolts are good for up to 10 PSI of boost if the head gaskets are fresh.
Yes, you can turbocharge it.;Sweet
k_williams1982
'01 Excursion 4x4
Santa Rosa, CA
I have my 6.9 ATS turboed and getting ready to IC (intercooler) it.;Sweet 10psi?:dunno I thought 12 psi was okay... I've hit 12psi only for a short period, but try to keep it under 9 psi just to be safe. BTW, I have a doors on my '86 parts truck, but shipping would be pretty pricey.:eek:
david85
You may not actually blow the head gasket in a big puff of steam, but you can weaken the fire ring enough to cause a minor leak if you go past 10 PSI. The engine will probably still run fine and might not even have a coolant problem for a while but its possible to actually have the fire ring on the head gasket get deformed enough to allow combustion gasses to get past and cause erosion of the head and block mating surfaces.
When I tore down my engine for the overhaul I had this exact problem even though I had good compression (410 was the lowest) and good power. No coolant probems either, but there was slow and steady erosion happening in there without me knowing.Some have gone to 15 psi with stock 6.9 head bolts. You might just get away with it, but I'm most comfortable with telling people 10 PSI is the safe/reliable limit for a 6.9.
If my engine still had stock head bolts, I would probably enforce a 7-8 PSI limit, but tend to be more cautious and prefer reliability over power. Even 5 PSI will make a big difference in power over N/A.
