tbrumm
I am going to be taking my truck in soon to have the AC system evac'd, leak checked, recharged etc. by a local shop. I don't think I have any leaks as the system is holding pressure and does cool somewhat. This is a dealer installed AC system with an expansion valve. It has a newer parallel flow condenser, the Seltec compressor seems to run okay and is quiet, I have cleaned out the evaporator and that seems to be fine. The problem I continue to have is the low side pressure is still too low (20-25) and the evaporator seems to be freezing up blocking the system. The thermostatic switch does kick out the compressor when the system freezes up but then it takes quite a while for the evap to thaw and to engage the clutch again. Anyway, I want to purchase a new receiver/dryer and take that along and have the shop install that when they evac the system. Unfortunately, I can't find any part number or markings on the dryer to tell me which one to get. I have attached a couple of pictures so I am hoping you ac gurus can tell me what kind of fittings are on the dryer. It obviously has a binary switch on it too. Any suggestions on where to order it form? Thanks very much for your help! Todd
