clanky
Hello. I have a 84 6.9 all stock. I have fuel leak coming from under the ip. I found the leak yesterday,and drove the truck 25 miles. The truck sounds like the timing is retarding a little. Then the rattle comes back along with power.1) Is it ok to continue to run this? 2) will it damage the pump or engine? 3) I have a old pump that was removed from a running 94 factory turbo 7.3. Could I put this on? 4) the core charge for the turbo pump is more than that of the n/a pump. Would any of the members who rebuild pumps give me a deal on a rebuilt n/ a pump if I gave you the turbo pump as a core. I need some advice. Thank you.
