Need help with fuel leak
mobilemech
Redding CA.
another source for the olives is a John Deere dealer, all the JD engines with the rotary style fuel systems ( low presure, less than 2500psi. ) have return lines that use olives like our engines. As stated Russ includes them with his return line kits, but this is another source for them
homelessduck
WHAT THE FOOSE BALL! ! I drove to town twice, no leaks when I got home. I checked again this morning and fine this :
. I can't tell if it's fuel, oil, fuel and oil, coming from the front or back. I will try the powder trick.
This is after being parked nose down, though it looks the same when parked nose up. My driveway is very steep and it is hard to tell if it is running forward or back. It does NOT leak while driving! ! Also, the small little black specks .. no idea where it's coming from. The valley pan was clean so it is coming from the leak.
truckonfire
