Guys this thing is *****, I found the running light wire along the rail, I found the white grounds at the end of the frame on the drivers side. Behind the rear tank the is a couple of what looks to be oem connectors, after the big connector the wire went dead ( no juice) ok easy enuff I will run a jump line to bypass the conector on the one wire. (no go) after I did that I still have no juice, So I go back to were I first spliced it ( before the wire harness) and theres juice. Its like theres just enuff volts to turn on my testlight, I thought this would be a no brainer, ( boy i was wrong ) I also don't have an amp meter here at work tonight, I just want to be somewhat safe on the ride home in the early morning. THX
