need help ASAP, return lines
Optikalillushun
Coal Region, Pa
on the injector by the filter head, very first on the left hand side...i cant get the nut to loosen off the injector. all the others were easy and this is being a PITA. i can see the line spinning so i stoped as i dont want to break it off. also attatched to it looks ot be some kind of spacer that moves with the line nut. there is also a plastic cover on the very bottom. the injector also looks to be longer then the rest.
how can i get the line off? i soaked it w/ PB blaster and it still doesnt budge -cuss
suv7734
BC Canada
The 'spacer' you see is the timing adapter. You'll need to use two wrenches (5/8") to loosen the line. The first wrench turns the line 'nut' the second holds the hex part of the adapter. If you don't use two wrenches you'll be trying to spin the adapter on the injector but the line nut isn't loose so it won't spin other than if you twist the line.
Optikalillushun
Coal Region, Pa
whew, good to know! it is also very rusty so i gave it another shot of PB.
where is the second 'nut'? under the little sleeve? it moves but not enough for me to see what is under it.
suv7734
BC Canada
Kind of a lousy pic but you'll get the idea.
GREASE FIRE
Falmouth KY
what does the timing adapter do?
i noticed that on my truck and was wondering what it does?
thanks
Paul
ntjapkes
