Need an idea where to get a replacement plug connector
Wheelhorsewilly
Marysville, Ohio
It is part of the glow plug harness, the enclosure for the 2 end wires broke ot.
chillman88
Central NY
That's a common problem area on these. Personally I'd follow @riphip advise. I actually replaced those wires completely on mine with some 4ga.
The problem is that connector gets corrosion built up over time and causes resistance which causes heat. When that happens if you're lucky it'll just melt the connectors a little bit, if you're not, it'll catch fire.
Seven4eight
