Sounds like you need an injector return line kit installed.Pretty easy to do your self.Kit cost around $35.Comes with new plastic caps,16 O rings for the injectors,The Cloth covered return line(Synthetic rubber inside),and clamps.To do the install you remove the Line clamps(the flat thingys) on the Metal lines,loosen the line nuts at the injectors(gotta use 2 wrenches on the #1 front passenger side due to the timing hicky.Remove the line then the timing hicky on this one),carefully move the lines away(don't bend them just flex them),pull the old return line caps and hoses as a assembly if you can.Use a dental pick or as I did a set of needle nose pliers to pull the old O rings off.Lube up the new O rings with Petrolium jelly or the likes.Now install the new O rings carefully.Top one first so you can just roll the next one over it onto the bottom groove.Again be careful not to cut them or nick them.Now use the old return line setup as a template and prebuild the new assembly on the bench and install it one bank at a time.The 94 setup has some T caps that usually doesn't come with the kit but doesn't matter.All it has to do is allow the fuel to be able to return to the original pickup points.Both banks be connected and have one line to the IP and one line to the rear fitting to return to the tank.It takes me about 2 hours to do one and I have fat hands and am lazy so I take my time!
