Muncie hydraulic pump kit 92-94 idi
cardana24
Virginia
I am selling this hydraulic pump set up It was bolted to a factory turbo engine. At a minimum the hydraulic lines would need to be replaced. This is listed as fitting a 92-94 idi. I am in central va and would prefer local pick up since some of this stuff is heavy. I’m asking $300
Here are the install instructions and parts list from Muncie.
https://www.munciepower.com/cms/fil.../Documents/Clutch_Pump/CMKF927300AAC_0194.pdf
cardana24
Virginia
u2slow
bilge rat
PNW
These are typically used in wreckers (tow trucks) with auto trans, since there's no PTO port.
cardana24
Virginia
What accessories was this pump used for?
When I bought the engine and trans I was told it was installed on a bucket truck. I assume it can be used for anything that can be operated with hydraulic pressure. Let me know if you are interested in it.
