MLPS Wiring missing
R.Shackleford
Ozark, Missouri
Alright so I bought a new neutral safety switch. Removed the old connector and rewired it to the new connector. When I discovered two wires cut about 10 inches from the connector itself. They are the
Electric Transfer Case Module and the PCM Body Ground Circuit. Both are black wires opposite ends on the first row of the connector.
Does anyone know where these wires go? because now I cant start my truck at all. In park or neutral
Any additonal advice on the MLPS would be a great help as well.
Thank you!
trackspeeder
Stone crusher.
North Branford. CT
Recheck your pins. Good chance the connector is wired reverse. Other word it's off by 180 degrees.
If you do not have a T case shift motor, ignor that wire.
R.Shackleford
Ozark, Missouri
Thank you. I wired it up as is and turns out the N slot was just a hair off. Starts right up now! (So far...)
Thank you for the response. Got my IDI back on the road!
Staff online
