Making a down pipe?
scfdiesel
wilkesboro, NC
I'm needing a down pipe to fit the 3" outlet housing on the ATS turbo, I think its a slip fit. Just wondering if anyone has any experience with this? The down pipe is no longer available from ATS. Any insight would be greatly appreciated.
mobilemech
Redding CA.
do you have the old pipe? I had an exhaust shop copy one. you might be able to use a down pipe from a powerstroke and cut off the 90 and mod it to fit, the powerstroke pipes are 3"
boosted power
Troutdale, OR
A powerstroke downpipe can easily be modified to fit. Not sure about how you are attaching it to the outlet elbow though. The factory setup uses a v-band, and I think the ATS setup uses a bigger v-band.
nope. no v-band.
slip fit tube. see pic. oem on the left.
boosted power
Troutdale, OR
Oops thanks Towcat, guess my memory isn't as good as I thought. I changed it to a ball flange so that it would be easier to install and remove. :dunno
