Cheaper Jeeper
Yours sounds about like mine. I've been told to check for two sure indicators of whether it is a minor problem or a major problem. First, with it idling, pinch off the hose to the CDR then take the oil filler cap off and try to seal the oil filler neck with the palm of your hand. If it builds more pressure than you can easily hold back with your palm it may be serious. Secondly, with the filler cap off rev the engine. If the blowby dissapears by 1000-1500 RPMs, it isn't too serious. If it doesn' then it may be a signficant problem.
Fortunately for me, mine passes both those tests. I am giving it the AutoRx treatment though, just to see if it improves. I have to say that stuff blackens the oil, like RIGHT NOW. I haven't driven mine a full 100 miles since changing the oil and adding the AutoRX, and the oil looks black enough to be ready to change already. I have to assume that it is so black because the AutoRX is cleaning all the gunk out of it.....
