seawalkersee
It needs a turbo...
I am trying to wire in the 6.9 to my bronco. Thus far, the only real info I can find is later year wiring diagrams. I have most of the wiring but it was butchered by a deer from the doner truck. I would like to see a pic of the after glow relay, the wait lamp/latching relay, and the glow plug control unit. I THINK I know which is which.
I have two relays that looked like they hooked to the fender and are heavy duty (like a starter relay) and a smaller (than those) that has a metal top. I am pretty sure the one that is not the main power relay is my after glow relay and the smaller one with four plugs (white with a metal silver top and square) is my wait to start relay. As far as the glow plug controller, the ones I can find pix of is a square piece on the rear of the engine. I have a round plug that is about twice the size of my thumb. Is that the correct one?
Next, Is plug #3 on the after glow relay supposed to get a constant 12v from the alt while running?
I have looked at the moostang photo album and have cut a ton of the crap out of the harness from just tbe junk scotch locked to the harness and the old alt stuff (swapping to a 3g). I just want it to go smoothly and could use a bit of a boost...per say.
One more thing special for Mel, my engine is touching the body at the rear on the drivers side. I hav 3" of body lift on it. Do/did you have the same problem?
Chris
Chris
