lift questions
imelmo
Slidell, LA
Well, Diesel Innovations "made" me buy a set of 37 x 12.5 rims and tires they had while I was getting some other stuff done and I had a couple of questions about what size lift I would need.
From what I've seen, an 8 inch lift is what's recommended. Can I do a 6 inch lift with the cut-away fender flares instead? And I probably will be going off-road occasionally.
Also, can I put the 6 inch lift on w/o the flares as long as I don't go off-road? I'll just get the flares later if I can.
Don't know if this makes a difference but these are Goodyear Wrangler MT/R tires mounted on MB Motoring Rocker Wheels.
Thanx for any help.
Swany
Consiglieri
California
If you're going with the Edge lift, you should be able to fit those tires with a 6 inch lift. Any wider of a tire and I'd recommend you go to an 8. This way you'll have a bit more travel.
jchellen2
